2 Pages<12
madmak
#11 Posted : Tuesday, January 5, 2010 4:45:36 AM(UTC)
madmak
Hi there have u gotten ur answer to how to reinstall the unit, if so can u please post it or sent it to me on mak13666@gmail.com it will be much appreciated
Originally Posted by: 95yj Go to Quoted Post
I was looking for information on how disconnect the two halves of a split air conditioning unit without losing any freon. I'm not sure if the manual I have explains the installation since it is in español but I'm looking for general information for all mfgs.
Basically, the airco comes with the inside and outside halves separated and capped with the full freon charge in the condenser. During installation the copper tubing is connected between the halves and the unit is bled to remove air using the compressor of the unit and a set of airco gauges.
It is also possible to "suck" all the freon back into the condenser/compressor leaving the evaporator dry. This is used for disassembling the unit for moving or for cleaning the inside unit.
Does anyone have detailed instructions on how to separate the units without losing freon and to reinstall them? I have gauges and have recharged units before but have never worked on a split unit.
Thanks much.
madmak
#12 Posted : Tuesday, January 5, 2010 5:03:52 AM(UTC)
madmak
Hi there, i was just looking for the same answer, can u please let me know hot to reinstall the unit, the info about the removal was as clear as water, thanks
hvac_hillbilly
#13 Posted : Thursday, January 7, 2010 5:45:46 PM(UTC)
hvac_hillbilly
umm i think i would call a local contracter to reinstall unit for you there is qwite a few things that you can mess up including the compressor and you just lost more money than your trying to save
2 Pages<12
