eugenecjr
#1 Posted : Monday, January 4, 2010 8:59:07 AM(UTC)
eugenecjr
Stove at some point was switched from Fahrenheit to Celsius. Have looked all over for a user/operations manual for the stove but have had no luck. Any idea as to where I can get the user/operator manual or switch the stove back to Fahrenheit?
Regards,
-Eugene
#2 Posted : Monday, January 4, 2010 11:53:34 AM(UTC)
Eugene,
The model number you posted does not come up. It might be incorrect, incomplete or just too old.
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
TOTW
#3 Posted : Tuesday, March 9, 2010 5:32:14 PM(UTC)
TOTW
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
UVMSJIM
#4 Posted : Friday, January 20, 2012 6:57:44 AM(UTC)
UVMSJIM
[FONT='Tahoma','sans-serif'][FONT='HelveticaNeue-Roman','sans-serif']The temperature is preset at Fahrenheit, but can be changed to[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif']Celsius.[/FONT]
[FONT='HelveticaNeue-Bold','sans-serif']1. [/FONT][FONT='HelveticaNeue-Roman','sans-serif']Press and hold the upper oven BAKE and CANCEL pads[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif']for 3 seconds. A beep will sound and the current setting[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif'](°F or °C) will appear in the display.[/FONT]
[FONT='HelveticaNeue-Bold','sans-serif']2. [/FONT][FONT='HelveticaNeue-Roman','sans-serif']Press AUTOSET to change the setting. Wait 4 seconds for the[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif']new setting to be accepted.[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif']If AUTOSET is not pressed within 30 seconds, the control will[/FONT]
[FONT='HelveticaNeue-Roman','sans-serif']return to the existing setting.[/FONT][FONT='Arial','sans-serif'][/FONT]
[/FONT]
