mattfromvermont
#1 Posted : Sunday, January 3, 2010 4:49:09 AM(UTC)
mattfromvermont
I have a GE Spacemaker Microwave oven, model HVM 1540 and the fan does not shut off automatically after the microwave turns off. Even when it is cold and after a short 30 second microwave cycle the fan goes up in volume and speed and won't shut off until 6, 7, 8 "push fan" cycles (hi, lo, off). Many times it won't shut off at all and I have to "pull the plug". What is the problem and can I do it myself? Lately the light is doing the same thing. Thanks very much!
cinfinn
#2 Posted : Friday, January 15, 2010 7:21:03 AM(UTC)
cinfinn
I have the same model and it will not shut off, no matter what button I push. I have to leave the door open or unplug it. Would be interested to see a response for this, too.
#3 Posted : Friday, January 15, 2010 6:09:15 PM(UTC)
Hi Matt,
Sorry for the delay.
I'm assuming you are talking about the hood fan. This fan controls by the microwave control board which most likely is the culprit.
- The control board Part number: AP3994110
#4 Posted : Friday, January 15, 2010 6:12:30 PM(UTC)
In your case sounds like the problem is a cooling fan. You may want to check the upper and lower door switches (#1446 on the diagram).
- The interlock switch Part number: AP2622452
GE Spacemaker microwave door problem (Microwave Repair)
by pop g 10/28/2012 2:22:40 PM(UTC)
GE Spacemaker Microwave remove keypad (Microwave Repair)
by dentonma 1/15/2012 6:16:19 PM(UTC)
GE Spacemaker microwave (Microwave Repair)
by rhonda.dyer@att.net 5/26/2009 7:36:27 PM(UTC)
