2 Pages12>
ricfal
#1 Posted : Monday, December 28, 2009 9:19:54 AM(UTC)
ricfal
My Amana Refrigerator which is about 8 years old and is now acting up. The ice maker is malfunctioning (stopped working) and the freezer is not cooling properly. The frig side and the water on the door, work fine. I have vaccummed the front and back areas (including the fan). What else should I do ?
Any suggestions are appreciated....
Thanks,
Rick
#2 Posted : Monday, December 28, 2009 11:39:32 AM(UTC)
Rick,
The ice maker will never work properly if the temperature in the freezer is more than 15°F.
Remove the rear panel in the freezer and check how the evaporator coils are covered with snow.Check if the fan in the freezer works properly. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA ARS2667AS Ref - SXS/I&W | AppliancePartsPros.com
James Richards
#3 Posted : Tuesday, December 29, 2009 2:53:59 PM(UTC)
James Richards
my ice maker is not freezing i think it is cycling to soon which is not giving it time to freeze properly. it is a brand new ice maker that i ordered. are there any adjustments on the icemaker that i can adjust
#4 Posted : Tuesday, December 29, 2009 3:43:14 PM(UTC)
What is the exact temperature in the freezer?
How long time takes for one cycle?
ricfal
#5 Posted : Wednesday, December 30, 2009 10:58:27 AM(UTC)
ricfal
An odd event occurred today, the ICE maker cycled and made a set of ice cubes. I dismantled the rear freezer panel and found the top two layers of the coil had ice on them. Not sure what to do next ?
James Richards
#6 Posted : Wednesday, December 30, 2009 5:04:11 PM(UTC)
James Richards
im not sure what the temperature is but it is set at the coldest maximum temp and is working properly for the frozen foods that are in the freeezer
James Richards
#7 Posted : Wednesday, December 30, 2009 5:06:53 PM(UTC)
James Richards
my ice tray that catches ice is full of frozen water and frozen ice is dripping out of the trays
#8 Posted : Wednesday, December 30, 2009 10:38:34 PM(UTC)
Turn the ice maker off to stop the water leak and measure the temperature in the freezer.
What is the complete model number of the refrigerator?
James Richards
#9 Posted : Thursday, December 31, 2009 3:55:38 AM(UTC)
James Richards
TS125TW Amana refrigerator
#10 Posted : Sunday, January 3, 2010 6:20:09 PM(UTC)
James,
Have you turned the ice maker off and measured the temperature in the freezer?
2 Pages12>
