2 Pages12>
watson-1
#1 Posted : Wednesday, February 27, 2008 7:12:57 AM(UTC)
watson-1
washer leaks water from tub above the transmission
#2 Posted : Thursday, February 28, 2008 9:40:02 AM(UTC)
Most likely the central seal (#26 on the transmission break down diagram) and the bearing (#26 on the motor/tub break down diagram) have to be replaced.
- The part number for the central seal is AP2142342
- The part number for the bearing is AP2131587
Here are the break down diagrams for the Frigidaire washer Model FWX233RES4
RicardofromPR
#3 Posted : Monday, March 3, 2008 4:17:32 PM(UTC)
RicardofromPR
Hi, I'm having the same problem with my Maytag (PAV3300AWW), undecisive on which part to purchase for the problem. Please help. Need part number.
#4 Posted : Monday, March 3, 2008 7:28:33 PM(UTC)
Hi Ricardo,
What exactly is wrong with your washer?
Post it as a new thread, please.
RicardofromPR
#5 Posted : Tuesday, March 4, 2008 11:02:43 AM(UTC)
RicardofromPR
In rinse cycle, tub collects water fine, turns really slow, and visual leak between tub and top part of what I believe to be the transmission. I'm understanding that the part that I need for this is tub and seal kit
# 35-2974. Is this correct?:confused:
Hi Ricardo,
#6 Posted : Tuesday, March 4, 2008 12:03:22 PM(UTC)
In order to fix this leak you have to replace the tub and seal kit.
The kit comes with the complete instructions and to do the job right you need a few special tools.
- The part number for the tub and seal kit is AP3875413
- The part number for the spring removal tool is AP3854720
- The part number for the seal nut is AP3873487
- The part number for the spanner wrench is AP3854730
Here are the break down diagrams for the Maytag washer Model PAV3300AWW
RicardofromPR
#7 Posted : Tuesday, March 18, 2008 1:01:43 PM(UTC)
RicardofromPR
Hi Gene, it's me again, I apologize for bothering so much. Would you know the part number for the ball bearings of the transmission of a Frigidaire Model #FWX833ASO? I'm assuming it's within the two seals. Please correct me if I'm wrong.
#8 Posted : Tuesday, March 18, 2008 2:05:49 PM(UTC)
Hi Ricardo.
As far as I know Frigidaire does not sell any transmission parts separate.
hybrid999
#9 Posted : Thursday, August 28, 2008 1:39:54 PM(UTC)
hybrid999
can one of you guys give me a bit of advice in order to take it appart. I am mechanically inclined but I can't figure out how to take the tub out ...
thanks a lot !
#10 Posted : Thursday, August 28, 2008 5:34:51 PM(UTC)
hybrid999,
What is the complete model number of the washer?
Guest (6)
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer leaks water while filling tub (Washer Repair)
by 2WHIRLPOOLSCLW 5/26/2013 4:57:28 PM(UTC)
Washer leaks water into tub continuously (Washer Repair)
by jray66cj 3/8/2012 5:47:01 PM(UTC)
washer leaks water into basket when not in use (Washer Repair)
by anne stromberg 7/2/2011 5:14:35 AM(UTC)
during spin washer leaks water from under nealth (Washer Repair)
by 21jam12 2/3/2010 6:03:43 AM(UTC)
washer leaks water out bottom (Washer Repair)
by jag11727 5/9/2009 7:36:08 AM(UTC)
dishwasher leaks water occasionally (Dishwasher Repair)
by jukenut 4/26/2009 6:40:48 PM(UTC)
washer leaks water (Washer Repair)
by centurionballer 11/20/2008 10:29:38 AM(UTC)
by puttputt1953 10/19/2008 8:18:14 PM(UTC)
Washer Leaks Water Into Tub After Cycle (Washer Repair)
by zinnco 7/29/2008 7:21:02 AM(UTC)
2 Pages12>
