I notice a puddle after my wash is done. It does not occur immediately after, but will be there a few hours later. We took off the back panel to check for leaks and noticed all the components were completely dry. Not sure where the leak is. Any ideas :confused:
Take off the front panel by inserting a screw driver in the gap between the top and the front near the edges to release the clips that hold it on.
Run the machine with the front off and you should be able to see it leaking and pinpoint the source.
Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Take off the front panel by inserting a screw driver in the gap between the top and the front near the edges to release the clips that hold it on.
Run the machine with the front off and you should be able to see it leaking and pinpoint the source. thank you we'll try that. Happy New Year! :)
