suree
#1 Posted : Monday, December 28, 2009 8:31:37 AM(UTC)
suree
I have a Magic Chef gas oven that stopped working a couple days ago. Up until then, it started up fine, heated food to the temperature and there were no problems. The stove burners still work.
I tried to light the pilot on the oven (not sure if it has one), went into the boiler area and lit a little caged part of the burner, but nothing happened? Any help would be appreciated!
Thanks!
#2 Posted : Monday, December 28, 2009 10:04:19 AM(UTC)
Most likely the problem is a bad oven igniter (#6 on the diagram), but better if you'll check it with a multimeter.
Unplug the igniter wire plug and check the igniter for continuity. Replace the igniter if the circuit is open.
If there is a continuity, check for 120 VAC to the igniter while the oven thermostat calls for heat. Post the result.
- The oven igniter Part number: AP4012072
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 6/6/2011 12:44:20 PM(UTC)
