bmmiller139
#1 Posted : Wednesday, December 23, 2009 8:32:33 AM(UTC)
bmmiller139
Hi:
I believe that 1 or 2 of my igniters are bad on my Jenn-Air cooktop. They sometimes keep clicking after the the burner ignites or keep clicking after another burner ignites (not the same burner).
The igniters are pretty cheap about $13. But how do I replace?
Do I take the nut of the top of the burner (gas) or do I need to take out the pan? If it is the pan that needs to be removed, I have already tried taking out all the screws, but it will not separate from the trim. Do I need to lift the whole unit out?
Any help greatly appreciated. Thanks.
#2 Posted : Wednesday, December 23, 2009 12:31:34 PM(UTC)
More likely the problem is a bad spark module. You can find the instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR CVGX2423B Surface Base Unit - Ddraft Gas | AppliancePartsPros.com
goacom
#3 Posted : Wednesday, February 13, 2013 7:57:20 PM(UTC)
goacom
Gene, is there I way I can get access to the manual? The link does not work anymore. I would like to replace my igniters, but cant figure how!
#4 Posted : Thursday, February 14, 2013 3:08:49 PM(UTC)
Sorry for the broken link. The access to this manual is not available anymore.
What is the complete model number of your stove and what seems to be a problem?
goacom
#5 Posted : Wednesday, February 20, 2013 7:03:43 PM(UTC)
goacom
Gene,
Thanks for the reply. My model # is CVGX2423B. My problem is identical to that faced by bmmiller139. Specifically, one of my igniters is bad, but I cant seem to be able to remove it. I tried removing the pan by removing the screws along the sides (see picture "pan screws"), but the pan remains stubbornly attached. I tried removing the nut that is attached to the burner base (see picture burner base nut), but it refused to budge. Just in case that particular nut was a problem, I tried loosening the nut on the other bases, but had the same problem. If I can somehow get under the burner base, I think I would be able to get the igniter out.
Thanks for any help you can provide.
goacom attached the following image(s):
cvbwood
#6 Posted : Saturday, April 6, 2013 6:35:50 AM(UTC)
cvbwood
Originally Posted by: goacom Go to Quoted Post
Gene,
I am having the same problem and have tried the same things. Have you found a solution?
tonytexasd
#7 Posted : Wednesday, July 3, 2013 4:45:33 PM(UTC)
tonytexasd
Hello, I need to replace a spark module under the burner base on the same model. Did the same steps as you. Did you figure out how to remove the base for access? Thanks.
Guest (7)
