Is there a manual, diagram online or can anyone tell me how to remove the water/ice cover on the front of the door so I can replace a broken water actuator? The refrigerator I have is a Frigidaire Model #FRS23KR4A Thanks !
I also replaced a broken water actuator recently. Although I got the water actuator replaced with relative ease my ice maker won't stop running now any I can't get the water to work at all. The ribbon connector did come off of the cover, but the other end stayed attached. Everytime I go to re-attach the connector the ice begins to go and the water won't work. Any ideas on what occured b/c I think it hs something to do with the ribbon connector falling off.
Have you had any luck so far? i have the exact same issue. Temporarily i have put the panel back on, but the ribbon connector is not attached inside as every time i had it in the water lever is dead and the ice won't stop. so as of right now nothing in the panel works...
Originally Posted by: Always Something ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Have you had any luck so far? i have the exact same issue. Temporarily i have put the panel back on, but the ribbon connector is not attached inside as every time i had it in the water lever is dead and the ice won't stop. so as of right now nothing in the panel works... NO, I have had no luck yet. I did order a new ribbon to see if that is the problem. If this doesn't work I guess I will break down and call someone to come out and fix it.
Did you find a fix? I am having the same problem
Originally Posted by: jasmine31577 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I also replaced a broken water actuator recently. Although I got the water actuator replaced with relative ease my ice maker won't stop running now any I can't get the water to work at all. The ribbon connector did come off of the cover, but the other end stayed attached. Everytime I go to re-attach the connector the ice begins to go and the water won't work. Any ideas on what occured b/c I think it hs something to do with the ribbon connector falling off. I am having this same issue as above and numerous other threads I've seen but can't seem to locate a thread on what it's caused by or the final fix. It seems like there might be a reset or something causing the issue. Or is the ribbon bad? Any help would be appreciated. My model is FRS6L9EESS1.
Did anyone figure out what the problem was? We just replaced our water paddle and when we put back, the water does not work and the ice runs constantly..... Before I order a new board would love to know what it is
Hello, I am having the same issues as everyone else, but with the water instead of the ice. After I replaced the actuator and reconnected the wiring, the water stays running and the ice does not work. Did anyone find a solution? I disconnected the fridge and connected it again to see if it would reset, but the problem was not resolved. Any suggestions?
