jhabetler
#1 Posted : Sunday, March 2, 2008 1:17:47 PM(UTC)
jhabetler
Dryer is 1.5 yrs old and started acting up a couple weeks ago; but not all the time - it works fine for a couple loads, then won't stay running in any mode (timed drying or automatic drying).
Dryer will run for about 30 seconds, then stop - no error on the display.
Cleaning the moisture sensors sometimes fixes it...Letting it sit for a few minutes sometimes fixes it.
Should I consider replacing the moisture sensor.
Can anyone supply a wiring diagram for my dryer.
Thanx,
Justin
#2 Posted : Monday, March 3, 2008 12:14:11 PM(UTC)
Hi Justin,
The first failure suspect is a clogged exhaust line which caused the dryer to overheat.
jhabetler
#3 Posted : Monday, March 3, 2008 2:38:15 PM(UTC)
jhabetler
Thanks for the response Gene.
I actually already checked the exhaust line and it's perfectly clean.
Could it be a defective thermal switch?
Or should check something else?
Thanx,
Justin
#4 Posted : Monday, March 3, 2008 3:05:34 PM(UTC)
Possible the moister sensor is causing the problem.
The model number you posted does not come up. Verify and repost it, please.
jhabetler
#5 Posted : Tuesday, March 4, 2008 4:59:34 AM(UTC)
jhabetler
Model number is confirmed to be WTMC4300CN, Bosch Nexxt DLX Series Electric Dryer.
It's a Canadian model - the US equivalent is WTMC4300US.
Can I simply jumper the moisture sensor to bypass it?
Does it provide a variable resistance or some other measurement to the circuit board?
Thanx,
Justin
#6 Posted : Tuesday, March 4, 2008 11:23:45 AM(UTC)
Justin,
You can not bypass the moister sensor - the control board is going to be confused. It controls the sensor by reading the proper resistance.
I would recommend to call an authorized Bosch tech because the problem you described is not a regular and it is not on the troubleshooting list.
jhabetler
#7 Posted : Tuesday, April 1, 2008 4:41:57 PM(UTC)
jhabetler
As it turns out the problem was with the door switch - the one screw holding the door sensor in place was slightly loose, just enough to shut down the dryer after a couple minutes of tumbling and clothes bumping against the door.
Go figure....
#8 Posted : Tuesday, April 1, 2008 6:44:27 PM(UTC)
I'm glad you were able to fix it.
Guest LANCE
#9 Posted : Saturday, July 3, 2021 8:27:44 PM(UTC)
Guest
MODEL NO WTL6500AU/07 BOSH MAXX DRYER
IT JUST SEEMS TO PULSE EVERTY FIVE SECONDS NO MATTER WHAT I DO ONCE TURNED ON HELP PLEASE .HAVE CLEANED ALL AREAS OF MACHINE
REGARDS LANCE
Guest (5)
