Maytag2075
#1 Posted : Friday, December 18, 2009 9:18:52 AM(UTC)
Maytag2075
Sensor for starting and stopping cold water does not work. Can you tell me wht part needs to be ordered?
#2 Posted : Friday, December 18, 2009 4:01:03 PM(UTC)
Replacement parts for A506 models | AppliancePartsPros.com
Looks like a standard fill valve which does not have a sensor.
Note that I could not confirm this as I cannot find a wiring diagram.
What is the problem?
Maytag2075
#3 Posted : Saturday, December 19, 2009 9:11:48 AM(UTC)
Maytag2075
The problem is that I have to manually turn the cold water on and off to fill the tub with water or stop it from overfilling.
Thanking you
#4 Posted : Saturday, December 19, 2009 11:55:56 AM(UTC)
Yes if the only way to shut the water off is by shutting off the tap then you need a new valve assembly. A valve is stuck open.
If you can shut it off by just unplugging the machine then your problem is elsewhere. This could be the timer or more likely a problem with the water level switch.
Guest (8)
New flame sensor failure? (Dryer Repair)
by spiderberg 4/1/2009 6:54:40 AM(UTC)
