acinom
#1 Posted : Thursday, December 17, 2009 1:33:00 PM(UTC)
acinom
The oven baking element in my oven blew up....sparks and all. We replace the element and now it still does not work. What should we try next.
Thanks for any help.
ctg51
#2 Posted : Thursday, December 17, 2009 4:23:26 PM(UTC)
ctg51
Remove one terminal from the element, ( LIVE TESTS ) make sure it does not touch anything...turn on the bake cycle, measure the disconnected terminal (meter set to A.C.volts) terminal to ground...Now measure the loose bake terminal to ground you should get 120 volts A.C at both tests. ..Did you measure continuity on the element???? New, bad element....
Kitchenaid oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by Rocky D 1/19/2023 5:12:04 PM(UTC)
Need Help Finding Oven Baking Element (Oven Repair (including Ranges and Cooktops))
by tcogsdil 10/21/2013 9:06:56 PM(UTC)
oven baking element wiring burnt out (Oven Repair (including Ranges and Cooktops))
by BobOscar 12/14/2009 1:33:50 PM(UTC)
by kgolden 8/20/2009 7:55:15 AM(UTC)
Upper Oven Baking Element (Oven Repair (including Ranges and Cooktops))
by bkpierce 4/8/2009 1:22:54 PM(UTC)
Replacing an oven baking element (Oven Repair (including Ranges and Cooktops))
by kgmc 12/3/2008 8:32:36 PM(UTC)
Oven baking element (Oven Repair (including Ranges and Cooktops))
by DJF 10/2/2008 9:00:06 AM(UTC)
Hotpoint oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by cameron 9/28/2008 5:51:27 PM(UTC)
