Greg Mitchell
#1 Posted : Saturday, February 23, 2008 7:28:44 AM(UTC)
Greg Mitchell
I have a front load Kenmore, it leaks but only during the spin cycle, is this the oring between the front and rear outer tub? Is it hard to replace?
Greg Mitchell
#2 Posted : Thursday, February 28, 2008 6:18:00 PM(UTC)
Greg Mitchell
Ithought there would be an answer by now, is it the question or is it the machine?
Thanks,
Greg
richappy
#3 Posted : Friday, February 29, 2008 3:06:46 AM(UTC)
richappy
Remove kick panel below the door and verify where the water is leaking. If it leaks at the tub seam, tighten all the tub screws, if it still leaks, you will need to remove the tub and replace the tub seal.
