tkeemm
#1 Posted : 17 years ago
tkeemm
my kenmore gas dryer will start up and heat up for about three minutes. then it will try to heat up again but the ignitor just starts up but there is no flame. Does anyone have any sugestions?
#2 Posted : 17 years ago
Most likely the problem with your dryer are a bad coils on the gas valve.
- The part number for the kit of the gas valve coils is AP2150379
tkeemm
#3 Posted : 17 years ago
tkeemm
thank you i will try to replace the coil. is it pretty easy to do? Do I need to take out the whole gas assembly?
#4 Posted : 17 years ago
In order to provide more accurate advise I need the complete model number of the dryer.
tkeemm
#5 Posted : 17 years ago
tkeemm
the model number is Kenmore, 11087878100 and the serial number is M90508095
#6 Posted : 17 years ago
Just remove the bottom panel.
You need a short Phillips screwdriver to remove the two screws holding the bracket on top of the coils.
dennisdaubenspeck
#7 Posted : 17 years ago
dennisdaubenspeck
dryer not going through cycle on auto dry timmer not adv workes on other cycles mod #tgdx640jqo
#8 Posted : 17 years ago
Did it get hot?
For more accurate advise I need more specific description of the problem.
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 11 years ago
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 13 years ago
by liz777 14 years ago
by kamputty 15 years ago
by pauleouellette 16 years ago
by bseibes 17 years ago
dryer does not heat up (Dryer Repair)
by dralonso 17 years ago
