I ordered a replacement control for a drop-in range (GE Mod J DP39W0W3WW) I was sent a sanyo/torisan to retrofit the original robertshaw control. The instructions were not complete and I have a few connections I'm not sure of. first, L1 (black wire, 3 connectors in series) bottom of photo above loose ground wire. there is only one place I can see to connect this, the male stud on the relay on right. Assuming the remaining two F. connectors are eliminated. the other is the male/female jumper (orange, left of photo) I have no idea where to use this. Can anyone help? [IMG]http://forum.appliancepartspros.com/ ![UserPostedImage](http://widget.slide.com/rdr/1/1/3/W/20000000042909ea/1/93/6hL2dX2A3T95Pn7l9gMsX4DhXq_jW-1Z.jpg) [/IMG]
If you can post the instructions which came with the new part - it might help better.
these instructions were good but I think must be missing a page. [IMG]http://forum.appliancepartspros.com/ ![UserPostedImage](http://widget.slide.com/rdr/1/1/3/W/200000000445ed16/1/77/Gm3C8emD6z8DLVGvIrMYr0Wpix3UFN64.jpg) [/IMG]
Unfortunately it's almost not readable.
Call the customer service of the company who sold the part to you. They should help you to get the full instructions.
if you click on the photo it should take to to the slide.com website where it is posted. once there, click on the photo, when it's open if you hover over it an enlarge icon should appear. click on that and get an enlarged (readable) version of the photo (whew!!)
