Please help does my refrigerator model gss22kgpccc have a defrost timer ? but i can't fine it if so what part should i buy?
thank you very much!
Do the test in my resonse above "help, unit not cooling", most probable problem a bad defrost heater.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Do the test in my resonse above "help, unit not cooling", most probable problem a bad defrost heater. Please help i already order the defrost heater kit and i already install the pink and the blue cable on the right side. What about the left side please help.
The heater comes witht the jumper installed, you should be good to go now.
Can someone help me please how do i install the Thermostat. I only see that the old wire the organge it connect to the blue wire and the pink connect to the pink wire. Do i have to cut it and rewire the thing but how please help! When i receive the thing it does not have any instruction come with it.
thank you!
If ypo are replacing the defrost thermostat, just clip the wires off the old one and use insulated but splices to connect up the new wires, polarity not important.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) If ypo are replacing the defrost thermostat, just clip the wires off the old one and use insulated but splices to connect up the new wires, polarity not important. I lost the nut to connect the wire and i think the pink and blue wire are burn out how do i can get a replacement for my model.
