vespa_1
#1 Posted : Wednesday, December 2, 2009 2:31:54 PM(UTC)
vespa_1
While cooking I discovered that the right rear burner was no longer heating. I replaced the pot on the left front burner which immediately became hot and continued cooking. Later when I returned it too was no longer heating. The left back burner and the right front burner continue to work.
Before I order new burners I would like to know if there could be another explanation for this problem. Should I do further checking before ordering new burners?
John Scott
#2 Posted : Thursday, December 3, 2009 3:14:22 AM(UTC)
Replacement parts for WHIRLPOOL KECC501GBL0 | AppliancePartsPros.com
Here is a wiring diagram and manual
http://www.servicematters.com/d...0Sheet%20-%203191793.pdf
https://secured.whirlpoo...5b310a/$FILE/4317269.pdf
Yes, check the wiring, could be a wire has burned off.
Also check the elements with a meter.
Just because both give the same symptom does not mean they have the same cause re: one could be burned out and the other may need a new infinite switch.
