jerryxl1800
#1 Posted : Tuesday, December 1, 2009 10:57:56 AM(UTC)
jerryxl1800
Our GE Profile Space-maker XL1800 when run at full power shuts off in 2-4 seconds and displays power interruption. The display flicker also when it shuts off. If you start it at power level of 8 it works fine.
applianceman
#2 Posted : Wednesday, December 2, 2009 9:52:58 AM(UTC)
applianceman
It is hard to say for sure but I think it is in the control board.
Range Repair Guide
gbell202
#3 Posted : Monday, March 1, 2010 1:17:23 PM(UTC)
gbell202
Mine does the same. Have you found a fix for it? I've called a service repairman and will post if/when I get new information.:)
applianceman
#4 Posted : Monday, March 1, 2010 4:34:54 PM(UTC)
applianceman
I have never personally seen this happen but I have read post about the magnetron interfering with the control board. Try this page http://forum.appliancepartspros.com/microwave-repair/63025-why-no-answer-2-second-shut-off-issue-spacemaker.html
I have never run across the in the field but apparently a common problem.
joyce mix
#5 Posted : Tuesday, June 28, 2011 7:49:07 AM(UTC)
joyce mix
Our microwave makes a very loud noise when running. Is this repairable?
timmuggs
#6 Posted : Sunday, July 3, 2011 3:23:53 PM(UTC)
timmuggs
We have a similar problem. The noise is like a growling noise. I remove the 'lazy susan' dish on the inside, and it still makes the same noise. Have you had any luck dealing with it?
GE Profile Spacemaker XL1800 (Microwave Repair)
by AnthonyXL1800 8/22/2008 7:32:25 AM(UTC)
