everything electrical works, but blows only cold air. no heat.:confused:
Check incoming power for 240 volts at the dryer receptacle and at the terminals where the power cord connects to the dryer... If 240 volts is present here then dryer disassembly is necessary to further troubleshoot the circuit using an ohm meter... Check the heating elements next...
