rayboy
#1 Posted : Sunday, November 29, 2009 3:25:10 PM(UTC)
rayboy
I'm trying to help out an elderly neighbor with his washing machine.
The machine refuses to spin and drain unless I hold down the lid switch with a screw driver. The plastic part on the lid that depresses the lid switch dosen't do it's job. Why does it work when I use a screw driver but not when the lid is down? It does go through the wash cycle with the lid closed but when it gets to the spin cycle it stops.
Would appreciste any feed back.
Rayboy
sidfink43
#2 Posted : Sunday, November 29, 2009 3:40:57 PM(UTC)
sidfink43
Hi Rayboy
The lid switch mechanism is broken, so that plastic lip that the plunger on the lid pushes to activate the switch is not moving enough to close the lid switch. When you insert the screw driver you are moving it more than the plastic plunger does, so it drains and spins.
Replace the lid switch and the machine should be up and running and you can congratulate yourself on being a really nice person to help your neighbor. Here is the part.
Part number: AP3094500
and here is site that will show you how to get the cabinet off to do it. Your model number is coming up as a Whirlpool, so I assume that is what you have.
Kenmore top loader blues (SublimeMasterJW's Appliance Advice)
rayboy
#3 Posted : Sunday, November 29, 2009 4:34:45 PM(UTC)
rayboy
Originally Posted by: sidfink43 Go to Quoted Post
Hi Rayboy
Congratulations go to you all for such quick and thorough replies. I very much appreciate it and I'll see what I can do! BTW: It is a whirlpool washer.
rayboy
#4 Posted : Tuesday, December 1, 2009 6:54:52 AM(UTC)
rayboy
Sid,
It took less than an hour to make the repairs on this machine. Not bad for a novice repairman like me, lol.
Your instructions were easy to follow and my neighbors are happy. I might add, my neighbors are in their late 80's so you can imagine how dependent they have to be sometime and were most grateful for your help.
sidfink43
#5 Posted : Tuesday, December 1, 2009 12:51:42 PM(UTC)
sidfink43
Well, sounds like you did all the work, nice going, glad you were able to help them out and thanks for the update.
Guest (5)
Washing Machine Lid Switch (Washer Repair)
by EEE 5/5/2008 7:04:30 PM(UTC)
