dirtracer9
#1 Posted : Wednesday, November 25, 2009 12:33:15 PM(UTC)
dirtracer9
i have a ge dryer and the timer has quit working on the automatic setting. i have replaced the timer and it was not the problem. is there something else that controls the automatic setting? the dryer works fine on timed dry.
#2 Posted : Thursday, November 26, 2009 5:23:46 AM(UTC)
Usually the timer in Auto mode gets power through the heating element when the element is shut off by a thermostat.
Many GE's use 2 elements perhaps one of them is burned out.
Also if you have a grounded element (element has broken or sagged and is touching the case), it will never shut off so you never get timer advance.
Unplug the unit.
Remove the wires from the heating coils.
Measure the coils usually around 10 ohms.
Then measure from each soil connector to the frame , all should be infinite ohms (open). If not you have a grounded element.
dirtracer9
#3 Posted : Thursday, November 26, 2009 5:35:54 AM(UTC)
dirtracer9
thanks for the reply. i will look into that and see what i can find.
