gcoop
#1 Posted : Wednesday, February 20, 2008 4:32:03 AM(UTC)
gcoop
i have a gas range,when the oven is turned on it ignites, then heats to the required temperature ,then it normally cuts out .when the oven cuts back in to reheat to the required temperature i get a gurggling sound from the oven, even as the tube is lit .it sounds like when your barbecue blows out in the wind .i have installed a new igniter and have checked the brass jet for wear and dirt.the flame tube appears to be straight over the jet and all holes free of dirt. where should i turn next.
#2 Posted : Wednesday, February 20, 2008 5:48:01 PM(UTC)
Remove the oven floor and the flame spreader.
Turn the bake "on" and watch the flame.
The approximate length of the flame of the oven burner is a 1/2" distinct inner blue flame.
If you see the distinct blue flame but lifting - close the burner air shutter (on the bottom of the burner tube) to the point where it will not cause the flame to lift or blow off the burner when cold.
gcoop
#3 Posted : Friday, February 22, 2008 8:42:38 AM(UTC)
gcoop
i have tried closing the air shutter and it makes no difference it still gurrgles with it opened or closed. your comments are appreciated!
#4 Posted : Friday, February 22, 2008 12:53:29 PM(UTC)
Remove the burner and, using a toothpick, clean the hole in the orifice.
gcoop
#5 Posted : Monday, February 25, 2008 2:44:56 AM(UTC)
gcoop
i removed the orfice checked and cleaned the tip and i also cleaned the inner tip and used canned compressed air , it seems to have cleared the problem i will try the oven for a day or two then advise further .thanks for the help
gcoop
#6 Posted : Monday, February 25, 2008 3:17:59 PM(UTC)
gcoop
oven now works,we have used it twice and all seems fine .thanks you were agreat help.
#7 Posted : Monday, February 25, 2008 7:29:24 PM(UTC)
I'm glad you were able to fix it.
Guest (7)
Gas oven problems (Oven Repair (including Ranges and Cooktops))
by Bumpbk 9/19/2011 8:26:32 PM(UTC)
