tryingtolearn
#1 Posted : Tuesday, February 19, 2008 3:13:20 PM(UTC)
tryingtolearn
I have a bad LG 2M246 - 310GF magnetron. The top of the unit has shorted against the cabinet and continues to arc. I've pulled it out but can't find a direct replacement. I've found other 2M246 models with the same ratings but not the 310GF. Are they interchangeable? Is there a 'universal' magnetron I can use?
2M246 310GF
C05M - 009852
:eek:
richappy
#2 Posted : Wednesday, February 20, 2008 2:46:25 AM(UTC)
richappy
Carefully check the waveguide above the magnetron hole, if burnt, your new magnetron will arc also!! New microwave time if so.
tryingtolearn
#3 Posted : Saturday, March 1, 2008 10:28:28 AM(UTC)
tryingtolearn
The part that holds the magnetron is burnt from the arcing but I can't feel or see anything inside the hole.
richappy
#4 Posted : Saturday, March 1, 2008 3:42:25 PM(UTC)
richappy
If the inner wall of the waveguide is pitted from arcing=new microwave time.
