bpsimmons
#1 Posted : Sunday, November 22, 2009 12:07:00 PM(UTC)
bpsimmons
Maytag washer will not fill on cycle start will only fill on rinse cycle, on all settings (reg, delicates, easy care)??
sidfink43
#2 Posted : Monday, November 23, 2009 1:35:40 PM(UTC)
sidfink43
Looking at the timer diagram on models similar to yours suggest that the timer is the problem, since the cam and contacts are the same for all fill functions on all cycles.
I would replace the timer and see if that does not solve your problem. I would also call in the order with your serial number to make sure you get the right one.
bpsimmons
#3 Posted : Tuesday, November 24, 2009 2:52:11 PM(UTC)
bpsimmons
Thanks for the help
Maytag Washer will not fill (Washer Repair)
by creeves 12/28/2014 12:41:20 PM(UTC)
Maytag Washer will not fill... (Washer Repair)
by kdollva 12/17/2007 12:30:48 PM(UTC)
maytag washer will not fill with water (Washer Repair)
by wjim 12/6/2007 6:22:05 AM(UTC)
