dstarr
#1 Posted : Thursday, November 19, 2009 4:07:32 PM(UTC)
dstarr
Freezer can get very cold, but refrigerator is 50+ degrees
#2 Posted : Friday, November 20, 2009 2:06:15 AM(UTC)
Replacement parts for rt14dk models | AppliancePartsPros.com
Here is a sample wiring diagram
http://www.servicematters.com/d...0Sheet%20-%209791409.pdf
Check that the evaporator fan is running.
If OK
Check that there is cold air coming into the fresh food section at the top back of the unit.
Remove the evaporator coil cover from inside the freezer and check that the coils are fairly clear. If heavily iced/frosted up you may have a defrost problem.
Here are a couple good sites with basic fridge repair/troubleshooting help.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
