I can turn my top convection oven on to any temp, when I hit start, it goes to 100 degree and stays on for about 30 seconds and then the 100 degree setting turns off. The oven doesn't warm up at all. The bottom oven works fine, as well as the clock. I can't figure out what to do to repair.
I am having the same problem; did you find a solution?
Originally Posted by: jsanders  I can turn my top convection oven on to any temp, when I hit start, it goes to 100 degree and stays on for about 30 seconds and then the 100 degree setting turns off. The oven doesn't warm up at all. The bottom oven works fine, as well as the clock. I can't figure out what to do to repair. For anyone else that came here looking for answers, i will be on a service call today about this issue, hopefully i will have a good enough memory to post my findings. 5/11/2017
