How do I replace the hinges on the oven door? Can they be replaced from the front without taking the sides off?
In most cases the door hinge can be removed through the opening on the door frame. Sometime the side panels have to be removed first. Let me know if you'll need the instructions on how to remove the side panels. - The part number for the door hinge (they are identical) is AP3868108. Here are the break down diagrams for the Maytag range Model MER5730BAWGene.
Thanks Gene. The hinges are on order. I'll let you know how I make out. Waldo63
Hinges replaced. They slipper right in from the front. Thank you very much Gene. Waldo63
I'm glad you were able to fix it.
