We have a Inglis Washer 31/2 yr old 3 cycle machine. It wash and spins OK, but will not rinse at all absolutely nothing happens, all I could hear ais a humming noise, no water , no pump, no motor. Please help, could it be the timer?
Check the cold water supply.
If there is nothing wrong - replace the water inlet valve.
In order to provide the right part number for the water inlet valve I need the model number of the washer. The model number you posted is incorrect.
Verify and repost it, please.
