5 Pages<1234>»
#11 Posted : Monday, November 9, 2009 2:39:11 PM(UTC)
Quote:
...I'll just take your word for it that the board or boards are bad...
I can not say I'm positive about it without proper diagnosis. I just told you which step should be next.
Measuring the incoming voltage to the optic boards can prove the boards are bad or can lead to some other problem.
- The PC boards kit Part number: AP3137510
foobydoo
#12 Posted : Monday, November 9, 2009 2:45:27 PM(UTC)
foobydoo
Understood, thank you again for your time, expertise and patience.
Marshal
#13 Posted : Monday, November 9, 2009 2:49:38 PM(UTC)
foobydoo
#14 Posted : Monday, November 9, 2009 3:07:09 PM(UTC)
foobydoo
One more quick question. Should I go with OEM or do you think after market board kits ore okay?
Marshal
#15 Posted : Monday, November 9, 2009 4:09:02 PM(UTC)
Such electronic parts is better to use OEM.
foobydoo
#16 Posted : Monday, November 9, 2009 4:17:14 PM(UTC)
foobydoo
Thanks, will post what happens.
Marshal
foobydoo
#17 Posted : Wednesday, November 18, 2009 9:56:26 AM(UTC)
foobydoo
Marshal
Well, the optic boards were not the problem. I've replaced the main unit and now the optic boards and still no ice. I just ordered a new water valve, we'll see what happens when I put that in. I don't think there is much left to replace!
Marshal
foobydoo
#18 Posted : Sunday, November 29, 2009 12:37:27 PM(UTC)
foobydoo
Marshal
Well....it's been 48 hours since I replaced the valve and still nothing. So, let's recap what I've done. Original problem was no ice. I replaced the icemaker unit, when I took the old one out I noticed the plastic shaft was broken and the gears were barely making contact with each other if at all, thought that was it, no dice, no ice. Next I replaced the optical sensors, still no ice. Next I replaced the valve and then just to be sure a new water filter. Forty eight hours later still no ice. I'm now thinking it's something simple I'm just overlooking. Ice maker is on, water is on, optical sensor is working, freezer temp is zero. Maybe something needs to be reset or the icemaker timer adjusted ...? Any ideas are welcome, I'm still trying to avoid a service call and those pesky wife comments.
Marshal
#19 Posted : Monday, November 30, 2009 7:55:30 PM(UTC)
Marshal,
Have you checked the plastic water feeding tube into the ice maker? It can be frozen.
foobydoo
#20 Posted : Tuesday, December 1, 2009 2:57:23 AM(UTC)
foobydoo
Marshal,
I initially used a hair dryer to heat it up and turned the unit off and it brought the temperature up to about 50 degrees. I also ran a flexible plastic wire about 6 inches up into water tube. Where would it be frozen and what is the best way to make for sure?
Marshal
Guest (11)
5 Pages<1234>»
