imangobran
#1 Posted : 17 years ago
imangobran
I dropped a tray on top of the Glass Door of the Range and somehow some of the juice from the cooking spilled on the glass and it went in between the exterior and interior glass. It can't be cleaned and it looks very ugly :mad: . Can I just replace the Door. Thanks
#2 Posted : 17 years ago
I need the complete model number of the unit. You can find it on the frame behind the bottom drawer.
imangobran
#3 Posted : 17 years ago
imangobran
Sorry for the delay in answering back, but here is the NO. 17B6641P001.
#4 Posted : 17 years ago
The model number you posted is not a valid GE model number. It should start with a few letters.
Verify and repost it, please.
imangobran
#5 Posted : 17 years ago
imangobran
Hi Gene,
Sorry about that :eek: . Here it is JG13908SEK2SS. Thanks
#6 Posted : 17 years ago
This model number does not come up too.
imangobran
#7 Posted : 17 years ago
imangobran
I hope I am getting it this time and really sorry about that. JGB908SEK2SS I must have read the B as 13 instead. Thanks
#8 Posted : 17 years ago
GE does not sell the whole door and you do not need it if nothing is broken. You can clean all interior parts. Look into the break down diagram and you'll see how simple it is.
Remove the door from the range and put it on a flat surface with the front of the door facing down.
Remove all screws holding the inner door panel. Remove the inner door panel and it's all yours.
imangobran
#9 Posted : 17 years ago
imangobran
Thank you veryyyy much.:)
Range door glass/moisture barrier (Oven Repair (including Ranges and Cooktops))
by stevirey 15 years ago
Gas Range Door Glass Replacement (Oven Repair (including Ranges and Cooktops))
by ronkat 17 years ago
