herman
#1 Posted : Thursday, November 5, 2009 2:23:28 PM(UTC)
herman
washer only spins in perma press cycle other two cycles won't drainor spin, but continues to off. somtimes if it is turned manually to one of the other cycles it will spin , but not all the time.
thank you for your help
dave:confused:
#2 Posted : Thursday, November 5, 2009 5:34:12 PM(UTC)
Check the motor for continuity between the White & Blue and between White/Black & Blue terminals. Post the results.
herman
#3 Posted : Saturday, November 7, 2009 11:45:52 AM(UTC)
herman
the console looks a little different , do the let and right plastis pieces just pry off/
thank you dave
#4 Posted : Saturday, November 7, 2009 1:03:32 PM(UTC)
Dave,
There are two clips (#8 on the diagram). Push them with a putty knife to release. Be careful not to damage the paint.
herman
#5 Posted : Thursday, November 12, 2009 1:53:58 PM(UTC)
herman
Dave,
now she says there is some kind of brown stuff on the clothing, not oil, it just crumbles in her hand. all she washed was underwear so nothing in pockets.do I have two problems?
#6 Posted : Thursday, November 12, 2009 2:04:38 PM(UTC)
I have no clue about the second issue.
herman
#7 Posted : Thursday, November 19, 2009 1:47:31 PM(UTC)
herman
Gene,
I have continuity at white & blue white/blackand blue.Whats next,
thanks dave
#8 Posted : Thursday, November 19, 2009 4:04:09 PM(UTC)
Dave,
Sounds like the problem is a bad timer.
- The timer Part number: AP3951308
Guest (5)
