dibl
#1 Posted : Saturday, October 24, 2009 1:11:44 PM(UTC)
dibl
Kind Readers,
I have a Frigidaire GLTF1670AS front load washer. The "Door Lock" light comes on, but the washer won't work at all. No water, no agitate, no spin. Anyone have any ideas as to what to check?
Thanks in advance.
- DB
sidfink43
#2 Posted : Sunday, October 25, 2009 10:36:45 AM(UTC)
sidfink43
I would replace the door lock assembly. Current goes through it first and it is probably stopping in there.
dibl
#3 Posted : Sunday, October 25, 2009 10:50:24 AM(UTC)
dibl
Thanks. Finally found the service manual on-line. Troubleshooting guide in the service manual suggests the door lock assembly should be replaced. That's what I'll do. Thanks!
- DB
sidfink43
#4 Posted : Sunday, October 25, 2009 11:00:48 AM(UTC)
sidfink43
Good, let us know how it turns out.
kekunz
#5 Posted : Sunday, November 1, 2009 4:34:52 PM(UTC)
kekunz
where did you find the service manual online? I have the exact same problem.
richappy
#6 Posted: : Monday, November 2, 2009 1:34:00 AM(UTC)
richappy
You should find the service sheet behind the front panel but, you will need a meter to check things. I had one that had a connector came loose.
