We replaced our heating element and when we restored power, the oven heated up without us turning on the oven and we could not control the temp. We unplugged ion fear of burning out the new heating element. Please give us advise. annie
A Model Number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) A Model Number may help others help you. Thanks - the model number is MER5770AAA. OUr Maytag stove/oven has been out for 5 weeks - any tips would be great. Thanksgiving is coming!!!
MOdel MER5770AAA in regards to the replaced heating element oven issue. Please help
Would that be expensive and how do we check for the control panel? We needc to decide to replace or attempt to repair on our own. The unit is 10 years old. Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
Control Panel is Item 2 in Section 2 $129.45
Safest way to check is: Unplug the unit Check the resistance of each side of the element to the frame. Both sides should be open (infinite ohms) If OK Undo one of the wires going to the element. Measure from that wire to L1 If your reading is not open (infinite ohms) then the bake element relay's contacts are welded together. |
