whirlpoolblues
#1 Posted : Tuesday, February 5, 2008 7:42:10 AM(UTC)
whirlpoolblues
I have a Whirlppol washer (model # LSQ9510LQ0) that will not spin. I have read some of the other posts with similar prolems, but the difference is that my agitator works fine and the machine drains fine too. I can hear the machine straining when it should spin, but it doesn't. If I reach inside (pressing the lid switch) and give the drum a turn (like a kick start) it will start to spin. I can't figure out if it is the coupling, clutch or something else.
whirlpoolblues
#2 Posted : Thursday, February 7, 2008 11:12:50 AM(UTC)
whirlpoolblues
I removed the motor and checked the coupling. There are no breaks or stipping, so I guess that's one less possibility. What could the problem be and how sould I proceed to continue troubleshooting this problem? Any help is appreciated.
whirlpoolblues
#3 Posted : Thursday, February 7, 2008 2:32:33 PM(UTC)
whirlpoolblues
I found a local guy who let me borrow a used motor to test. Problem solved.
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
Whirlpool Washer Won't Spin, Drain or Agitate (Washer Repair)
by dsagun 8/10/2016 5:19:50 AM(UTC)
Whirlpool washer WON'T spin dry . (Washer Repair)
by zombi71 1/21/2016 9:57:15 AM(UTC)
Whirlpool Washer won't spin/drain (Washer Repair)
by EHankins 9/23/2014 8:08:35 AM(UTC)
Whirlpool washer won't spin but will drain (Washer Repair)
by Mattdb 9/13/2014 7:03:09 AM(UTC)
whirlpool washer won't spin (Washer Repair)
by szoke76 7/26/2014 10:40:09 AM(UTC)
Whirlpool washer won't spin out (Washer Repair)
by fujidave 4/5/2014 3:34:25 PM(UTC)
Whirlpool Washer won't Spin or Agitate (Washer Repair)
by Jimmimech 1/12/2014 6:57:46 PM(UTC)
Whirlpool Washer Won't Spin (Washer Repair)
by armrkcin 12/22/2013 7:02:31 PM(UTC)
Whirlpool washer won't spin on spin cycle (Washer Repair)
by u71589 6/2/2013 6:23:26 AM(UTC)
Whirlpool Washer won't spin/agitate. Replaced Direct Drive Motor Coupling. (Washer Repair)
by millmoss 9/10/2012 9:52:02 AM(UTC)
Whirlpool washer won't spin (Washer Repair)
by troycoy12 5/30/2012 1:19:45 AM(UTC)
by chas0073 5/8/2012 10:27:28 AM(UTC)
Whirlpool washer won't spin, drain, or agitate (Washer Repair)
by mosierap 12/14/2011 3:57:37 PM(UTC)
Whirlpool washer won't spin on the gentle knit cycle (Washer Repair)
by Bowdaddy 4/14/2011 8:48:36 AM(UTC)
