My dryer & timer stop mid cycle. Sometimes the dryer will run for 10 minutes before shutting down, sometimes it will run for 30 minutes before shutting down. No rhyme or reason. Can anyone assist? Thanks!:)
THIS FORUM IS DEAD!!!!!!! |
I only use the dryer on the timed setting and have not attempted any of the auto settings. The dryer does start right away once stopped. I will check out the door switch and post back. Thanks for all of your help!:)
The switch in the door has some "play" in its' opening. After sliding it around a couple of times, I started the dryer and it ran for the whole cycle without shutoff. Any ideas on how to permanently address the problem? Thanks!:)
You could try bending the switch actuator or replacing the switch.
When bending it be careful you do not want to break it. |
When you mention the switch actuator, you are talking about the white switch on the door that opens and closes. Correct? If so, how would it need to be adjusted to avoid future problems? Thanks again for all of your help!:)
I hope I can explain this!!
Hold the part that goes to the switch with a pair of needle nose pliers. Then bend the part that touches the door out, so that the door contacts it sooner thereby closing the switch sooner or more positively. To be honest I am not sure that the needle nose are required or even if you can use them. |
So you are talking about the metal nipple attached to the dryer box that makes contact with the actuating switch? That makes sense. There is a bulge at the end of the nipple. Should I flatten the bulge with a pair of pliers to achieve a more positive connection? BTW - Sorry for the sexual slang, but it seems appropriate to describe the issue....:D
Your description was far better than mine. Thanks for the chuckle !!! |
