Jodil73104
#1 Posted : Thursday, October 22, 2009 4:06:19 AM(UTC)
Jodil73104
I have a Maytag washing machine that was purchased in 2005, after it fills with water and begins the wash cycle it makes a horrible loud clunking noise. I was able to change the dial to rinse and have the same thing happen after the refill. I changed to the dial to spin and was able to spin all of the water from the unit. Where do i start on diagnostics. The belt and tensioner pully are fine. I am thinking either transmission or bearing plate. any suggestions
Frank / APP Team
#2 Posted : Thursday, October 22, 2009 8:04:21 AM(UTC)
Frank / APP Team
If you can get the front off you should be able to determine if the noise is coming from the transmission. If it is that is a rather large and costly job. Besides the transmission you will also need to change the seals, and possible the bearings. Below is a picture of the transmission. There are a couple of different seal kits depending on the serial # of the unit.
I've also included a service manual for you to look over to see if it's something you'd want to tackle.
Part number: AP4372970
Frank / APP Team
#3 Posted : Thursday, October 22, 2009 8:08:59 AM(UTC)
Frank / APP Team
One other link you may want to check into, that may be causing the noise.
http://servicematters.co...ary/docs/TDL-0104A-B.pdf
Guest (5)
