craig h
#1 Posted : Tuesday, October 20, 2009 3:09:39 PM(UTC)
craig h
Whenever i try to set the cleaning cycle on my oven i get a series of beebs and then the word "DOOR" pops up on the screen and the cleaning cycle stops.
i checked to make sure there is nothing holding the door open (even a little) and try again but i get the same response. any ideas??
marggreg
#2 Posted : Tuesday, October 20, 2009 3:59:53 PM(UTC)
marggreg
I used the clean cycle last year and thought I would run it again. I select the run time and the display goes to dr, it never locks. How do I get to the motor? The lock motor is over a hundred dollars and it needs cleaning once a year. My wife spent two hundred dollars extra for a self cleaning oven. Rags and detergent.
Self cleaning problem (Oven Repair (including Ranges and Cooktops))
Belarus ve2zc 3/13/2014 11:24:43 AM(UTC)
Oven Self Cleaning Problem (Oven Repair (including Ranges and Cooktops))
by double-g 1/16/2011 8:14:09 AM(UTC)
Self-Cleaning problem Frigidaire (Oven Repair (including Ranges and Cooktops))
by Cantankerous 8/31/2008 8:31:40 AM(UTC)
