lOOKS LIKE A SEAL LEAKING UNDER DRUM, I WANT TO REMOVE DRUM AND AM HAVING TROUBLE DOING SO. DOES THIS DRUM LIFT OUT,I ALREADY REMOVED FRONT AND TOP PANELS AND LOOKS LIKE AGITATOR DOES NOT COME OUT EASY, REMOVED CAP AND SEE NO SCREW. ALSO WANT TO KNOW HOW BIG A JOB TO REPLACE THE SEAL UNDER DRUM
Originally Posted by: HARRY HEN ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) lOOKS LIKE A SEAL LEAKING UNDER DRUM, I WANT TO REMOVE DRUM AND AM HAVING TROUBLE DOING SO. DOES THIS DRUM LIFT OUT,I ALREADY REMOVED FRONT AND TOP PANELS AND LOOKS LIKE AGITATOR DOES NOT COME OUT EASY, REMOVED CAP AND SEE NO SCREW. ALSO WANT TO KNOW HOW BIG A JOB TO REPLACE THE SEAL UNDER DRUM Below is a link to the service manual for your washer. It should help you through the entire process. http://servicematters.co...ary/docs/RS3100007R0.pdf
