johnnydanger
#1 Posted : Sunday, October 18, 2009 2:22:45 PM(UTC)
johnnydanger
washer will not start i have diagnose the wahsher iam recieving a f70 code on the washer it saying to replace the ccu central control unit in the tech sheet .is there a way to reset this code or do i have to replace the central control unit .how would i go a about fixing it .
sidfink43
#2 Posted : Monday, October 19, 2009 3:17:14 PM(UTC)
sidfink43
Your model number does not come up, but if the machine is less than one year old it should be covered under full factory warranty, so call for service from an authorized tech.
JOHNNYD187
#3 Posted : Tuesday, October 20, 2009 5:31:10 AM(UTC)
JOHNNYD187
THANK I APPRECIATE YOU GETTING BACK TO ME THE MODEL NUMBER IS Model: MHWE300VW
sidfink43
#4 Posted : Tuesday, October 20, 2009 9:42:20 AM(UTC)
sidfink43
That number still does not come up, but yours may be such a new model that it is not in the system yet. You should still check your warranty, and look and see if the CCU has a separate coverage.
sidfink43
#5 Posted : Tuesday, October 20, 2009 3:14:45 PM(UTC)
sidfink43
Ok. it looks like you have a Whirlpool Duet sold under the Maytag label.
Here is a link to a site that is hosted by Technician Brian, who is probably one of the best, if not the best on diagnosis on the net. It shows his diagnosis of the F70 message and the difficulty of determining exactly what the issue is.
<title>Appliance Repair Blog[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MHWE300VW"][/URL]
Hope this helps, (and some thanks to Brian)
JOHNNYD187
#6 Posted : Tuesday, October 20, 2009 4:36:13 PM(UTC)
JOHNNYD187
thank you how do i replace this part
sidfink43
#7 Posted: : Tuesday, October 20, 2009 4:41:14 PM(UTC)
sidfink43
The top should come off by taking out screws in the back, which should give you access to the board. It should be apparent how the board will come off.
Unplug the machine, do something to control static electricity and plug in the new board connection by connection.
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool duet washer f71 and f70 codes? (Washer Repair)
by james ngo 6/14/2010 4:38:00 PM(UTC)
F70 Code (Dishwasher Repair)
by JOHNNYD187 10/14/2009 8:56:14 AM(UTC)
