strattm
#1 Posted : Sunday, February 3, 2008 4:46:45 PM(UTC)
strattm
I get water into & pumped out of washer but no water out of spray arm. I can hear water enter & drain from machine thru tailpeice. This breakdown occurred after weeks of a louder operating noise, mechanical in nature, than usual. Any Ideas as to what this problem may be?
#2 Posted : Monday, February 4, 2008 12:30:05 PM(UTC)
Most likely there is a foreign object inside the pump intake which could cause a damage to the motor and/or impeller.
Remove the lower spray arm and the filter.
Remove the screw holding the impeller cover (#10 on the motor & pump break down diagram). Remove the cover and check for any foreign objects.
- Here are the break down diagrams for the Gibson dishwasher Model GDB635RHS0
