2 Pages12>
laurendylanjustin
#1 Posted : Tuesday, January 29, 2008 4:16:19 PM(UTC)
laurendylanjustin
I have a Whirlpool Ultimate Care II washer, Model # LSQ8243HQ0. It fills with water, goes through all cycles and ultimately drains....BUT it does not agitate or spin. Clothes are still wet at end of cycle; otherwise I wouldn't have known to check, it sounds as if its functioning the whole time. (my husband insists it is not the lid switch).
#2 Posted : Wednesday, January 30, 2008 12:17:29 PM(UTC)
You can find the complete instructions in one of my previous posts: http://forum.appliancepartspros...83-washer-wont-spin.html
Here are the break down diagrams for the Whirlpool washer Model LSQ8243HQ0
steelyglint
#3 Posted : Thursday, January 31, 2008 10:15:34 PM(UTC)
steelyglint
Gene,
My whirlpool washer, model GSL9365EQ2, has the same symptoms named earlier in this string with the addition of a clicking noise. The name of the machine is the same as that mentioned earlier.
I had the back panel of the washer off and observed the operation of the electrical motor and the motor coupler. The coupler appears intact on both sides of the interface, although there is a small amount of a dark dust like debris around the coupler, transmission and on the bottom panel. During operation, the coupler spins and does not appear worn or damaged. I cannot view whether the transmission input shaft is rotating. There is no movement, or vibration, from the transmission to the agitator during this operation. Is it possible that the coupling on the transmission shaft is broken and spinning freely? Or is this clicking noise a symptom of a problem within the transmission itself?
Thank you for your expert feedback here and previously on this site.
richappy
#4 Posted : Saturday, February 2, 2008 1:28:30 AM(UTC)
richappy
Just pull the outer panel off, remove pump and motor and check the coupler, probably broken.
steelyglint
#5 Posted : Sunday, February 3, 2008 9:43:49 AM(UTC)
steelyglint
Thank you.
whirlpoolblues
#6 Posted : Monday, February 4, 2008 10:34:34 AM(UTC)
whirlpoolblues
I have a similar problem as the above. My machine does agitate, but doesn't spin. You can hear it trying and if you give it a hand start, it will get going and spin. Is this a clutch problem?
#7 Posted : Monday, February 4, 2008 8:44:26 PM(UTC)
Hi whirlpoolblues,
In order to provide the most accurate advise I need the complete model number of the washer.
Post it as a new thread, please.
iceman38
#8 Posted : Wednesday, March 26, 2008 4:29:08 PM(UTC)
iceman38
Must be a common thing. My Ultimate Washer LSQ9110LW0 seems to be agitating but only spins sometimes. If I have a heavy (weight wise) load, the spin cycle does not work and the clothes are soak and wet. If I start the entire cycle over with say 1/2 load, the spin seems to work. If I add more clothes for a full (heavy load), the spin will only work some of the time. Any suggestions.
#9 Posted : Thursday, March 27, 2008 11:25:43 AM(UTC)
Hi iceman38,
The first thing I would check is the drive block. If there is nothing wrong then the problem is a bad clutch.
You can find the complete instructions in one of previous posts: http://forum.appliancepartspros...ir/373-not-spinning.html
Here are the break down diagrams for the Whirlpool washer Model LSQ9110LW0
whirlpoolblues
#10 Posted : Thursday, March 27, 2008 2:54:56 PM(UTC)
whirlpoolblues
Iceman - My washer had similar symptoms. It would agitate but would not spin. Light loads would spin and heavy loads would not, but got gradually worse until it would not spin light loads. I could occasionally smell a feint burning rubber odor, but my washer is not a belt drive. I checked the coupler and all of the other common problems that people suggested and couldn’t find a solution. It turns out that my motor was dying. A local repair center let me borrow a used motor to test. Problem solved.
Guest (6)
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
by patkat3 6/13/2014 8:04:56 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Washer won't agitate or spin (Washer Repair)
by Jojam3000 12/17/2013 2:06:10 PM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
2 Pages12>
