Swapped leads on front ignitors. Problem followed. Half of my module has gone bad.(The discharge leads are obviously wired in a cross pattern from a twin source module). In the meantime, I have swapped leads on the module so my most used L/H FWD will work till the new part comes in. It was fast and all I needed was a# 2 Phillips! Thanks!!!!!!
I appreciate the follow-up. Glad to help.
