Linda French
#1 Posted : Monday, October 12, 2009 1:44:16 PM(UTC)
Linda French
I am trying to get the rubber gasket to fit my disposal. We were gone for about one year, and the gasket dried out and broke off bit by bit!!! Now when its being used I have to hold my hand over it to keep it from going everywhere! HELP? Thanks, Linda French:confused: P.S. My home is a 2000 Champion Manufactured Home over a basement. It did not freeze it just dried out.
Bob Gray
#2 Posted : Sunday, November 1, 2009 5:20:31 AM(UTC)
Bob Gray
Linda, I too have a similar challenge. I have the GC2000xe2 which is very similar and the same thing happened. At first I went to Home Depot and found a splash guard gasket that fit fine. There is no taking anything apart. You can leave it in place all the time. I have been using it for a little over a year. Or if you wish, you can find the part # , deinstall the disposal and replace it. We are replacing our countertop and sink, so that is the way we are going. I'd rather have the new flange (the part that shows). While I'm at it, I'll replace the mounting gasket (that is what they call it in the parts manuel).
Garbage disposal not working (Garbage Disposer Repair)
by Guest 9/25/2021 4:06:35 AM(UTC)
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 8:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 1:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 8:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 8:41:42 AM(UTC)
by jakester3 6/12/2012 5:43:27 PM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 12:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 5:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 11:24:18 AM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 11:47:44 AM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 7:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 4:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 7:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 8:12:02 AM(UTC)
