adepinto
#1 Posted : 17 years ago
adepinto
I could use a little help. My oven lights after a very long time - sometimes 30 minutes. From what I understand, My ignitghter is working, because I can see it glowing(fairly brightly), but I never tested it with a volt meter. All the burners on top work with out any problems. When the oven is not lighting, I do not hear or smell any gas. I am assuming that my problem is a faulty safety valve not letting the gas thru. Although, every once in a while the oven works fine without any problems. I don't think it's a thermostat or a contronl panel problem,( because once light the oven works ok) but I could be wrong. Does this problem sound like a faulty safety valve?, and is a faulty safety valve a common problem? Thank you.
Anthony
misterfixall
#2 Posted : 17 years ago
misterfixall
try replacing ignitor
fyxer
#3 Posted : 17 years ago
fyxer
Safety valves do go bad sometimes but not often,for example in the last five years i have change maybe two safety valves,this condition you have sound like a ignitor going bad, taking a long time to light is common when ignitor's are weak.
adepinto
#4 Posted : 17 years ago
adepinto
Thank you.
Gas safety valve - "manual lockout"? (Oven Repair (including Ranges and Cooktops))
by joea99 3 years ago
Oven gas control/safety valve (Oven Repair (including Ranges and Cooktops))
by Michael47 4 years ago
New ignitor draws too much current; will it cause the Safety Valve to not open? (Oven Repair (including Ranges and Cooktops))
by yoyopol2000 12 years ago
Dual Safety Valve Problems (Oven Repair (including Ranges and Cooktops))
by tanders1 12 years ago
Maytag oven slow to light, have replaced igniter and safety valve (Oven Repair (including Ranges and Cooktops))
by kellih 12 years ago
Ignitor/Safety valve problem?? (Oven Repair (including Ranges and Cooktops))
by HkyFrk 12 years ago
new safety valve (Oven Repair (including Ranges and Cooktops))
by smitty11 13 years ago
GE XL44 Safety Valve Assembly Replacement AP2022751/WB19K12 (Oven Repair (including Ranges and Cooktops))
by stefantomoiu 14 years ago
Igniter lights , replaced gas safety valve and over still wont light until you hit th (Oven Repair (including Ranges and Cooktops))
by bigdaddywyatt 14 years ago
Safety valve (Oven Repair (including Ranges and Cooktops))
by philetus 15 years ago
New safety valve large flames in oven (Oven Repair (including Ranges and Cooktops))
by minuteman 15 years ago
Oven safety valve (Oven Repair (including Ranges and Cooktops))
by WALJ 16 years ago
Safety Valve Problem ? (Oven Repair (including Ranges and Cooktops))
by rashaw 16 years ago
GE XL44 Ignitor / burner / safety valve replacement (Oven Repair (including Ranges and Cooktops))
by bhaughee 16 years ago
Help...A Gaffers & Sattler Oven Safety Valve is desperately needed. (Oven Repair (including Ranges and Cooktops))
by AdrienneInNY 16 years ago
