2 Pages12>
kirkz24
#1 Posted : Sunday, January 27, 2008 7:36:37 AM(UTC)
kirkz24
Hello to all,
I had visitors coming over for supper and wanted to heat up my French Onion Soup. I put the pot on the stove top on the left front side of my stove top. The right had side turned on and never turned off. The only way to turn it off is to unplug the stove from the wall or turn off the breaker.
Does anyone have any idea what this could be? Id love to be able to fix this myself.
Any help would be great.
Kirk Henry
Montréal, Québec, Canada:)
kirkz24
#2 Posted : Monday, January 28, 2008 7:09:14 PM(UTC)
kirkz24
From what I have been reading on the net, it could be my infinite switch
that needs to be changed. Can someone shed some more light on this sitiuation?
Its kind of hard to not have a stove anymore!! Hehe :D
ANY information would be greatly appreciated.
kirkz24
#3 Posted : Tuesday, January 29, 2008 7:09:05 PM(UTC)
kirkz24
There seems to be many problems with this
kirkz24
#4 Posted : Tuesday, January 29, 2008 7:17:00 PM(UTC)
kirkz24
Is this a Infinite Switch? If so, would the be my problem?
UserPostedImage
Is this Universal? So I can install this on any of the 4 elements? Perhaps If I can, maybe I can test the switch elsewhere to see if the problem goes elsewhere.......
Any Help would be great.
RegUS_PatOff
#5 Posted : Wednesday, January 30, 2008 5:59:49 AM(UTC)
RegUS_PatOff
The white block with 4 wires is the temperature limit switch, which would not cause the element to stay on.
The infinite switch pictured is for the warmer, and is different than the others.
This is the infinite switch you may need. Part Details - FRIGIDAIRE Control, surface element , dual , potentiometer, part number: 316239601
You could try swapping the (2) #54A in this diagram (NOT the #54)
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124111&brandID=1428&modelDesc=ELECTRIC%20RANGE&modelNumber=PLEF398ACA&documentID=R0110011&documentTypeID=PLDM&documentClassCode=PV&titleType=BACKGUARD&titleID=00001
kirkz24
#6 Posted : Wednesday, January 30, 2008 5:25:49 PM(UTC)
kirkz24
http://www3.sears.com/imaging/I...KGUARD&titleID=00001
Thanks for the reply. I did change the two 54A infinite switch and the same element stayed on when I plugged it back into the wall. THUS leading me to believe that my problem is not the switch. What would cause this element to always stay on (Small middle element)
Also, do you think that just perhaps the test I did by changing the two 54A is not a perfect test? Are they both IDENTICAL partnumbers?
Thank you.
RegUS_PatOff
#7 Posted : Wednesday, January 30, 2008 5:47:34 PM(UTC)
RegUS_PatOff
the (2) 54A are the same.
then it could be the # 97A's. you could try switching those, they may be different,
the new ones are interchangable.
Part Details - FRIGIDAIRE Board, user interface, part number: 316239500 $112
edited: updated: looks like you need the Power Board: Part Details - FRIGIDAIRE Board, power, part number: 316239400 $126
kirkz24
#8 Posted : Wednesday, January 30, 2008 5:56:44 PM(UTC)
kirkz24
Are you saying to switch out my 97A? If I do that could i make things worse?
What does the clock/timer have to do in all of this? Im trying to switch out the 97A now! (10:00 pm) Hahah. Im starting to go into withdrawls with out a stove! ( Im a Chef )
Ill let you know
kirkz24
#9 Posted : Wednesday, January 30, 2008 6:15:15 PM(UTC)
kirkz24
I switched out 97A and the same small element still turns on.
What other pieces should I be looking to as the culprite, (Other than the Timer/Clock piece?
RegUS_PatOff
#10 Posted : Thursday, January 31, 2008 1:10:44 AM(UTC)
RegUS_PatOff
I edited my previous post, it's not the CLOCK/TIMER, it's the POWER BOARD
or you could disconnect that part of the element (and tape the wire) and still use the rest of the stove
connection P7 (RF INNER) on the power board
File Attachment(s):
5995358768.pdf (867kb) downloaded 27 time(s).
2 Pages12>
