donnascruggs
#1 Posted : Saturday, October 3, 2009 9:02:12 AM(UTC)
donnascruggs
It drains fine, just seems as if tub is locked, will not agitate & makes a grinding noise.
sidfink43
#2 Posted : Sunday, October 4, 2009 12:50:13 PM(UTC)
sidfink43
Hi Donna
On this machine (I am assuming there is the number 110 before the model number you posted) one shaft of the motor turns the pump and the other shaft turns the transmission.
Since you say the machine pumps water out the conclusion is that the transmission is jammed and the grinding noise you hear is the gears in the transmission.
Here is the transmission part
Part number: AP3096209
