All runs but won't heat I found the rectifier diode coming off of the hv capacitor open would that keep it from heating up or do I need to search some more cap checks ok. Dick2256
Hi,
Sounds like a bad diode.
If you have a ohm meter make sure the magnetron is not shorted out to ground before you replace the diode.
I tried anpother diode from another machine that was about the same physical size and it didn't help I also tried another magnetron that wasn't the same number and it would start but then would shut down
