Hello,
We discovered that the washer has a slow not gushing leak. The water is appearing on the left side of the washer on the floor. We opened the washer and didn't see anything that seemed to be causing the problem.
The waterpump seems dry although about 6 inches away toward the back of the machine, the metal flooring brackets on the bottom was collecting water. We also watched the machine during different stages and still couldn't determine what could be causing this problem.
Any help would be greatly appreciated. Thank you, Donna
The discharge hose had a hole it. The vibrations caused by the washer during spin cycle caused it to rub the hole.
Thanks to everyone who read this thread.
Donna
Good job donnakay31!
