The blower motor will start even if I have the thermostat turned off. I have even disconnected the thermostat at the furnace and the blower motor still will start. Sometimes it will run for a few minutes and sometimes it runs for less than one minute. It will sometimes start up every 30 seconds and run for a short time. I have heard that this model furnace has had trouble with the early circuit boards and this could be the problem. Does anyone have any information on this problem? Thank you
Wow a furnace with a mind of it's own. LOL You never hear much about Jenn Air central unit I don't think it is a wide spread problem. You need to check for a stack pipe rain leak dripping on or near that board.
Furnace doesn't respond to thermostat
(Heating, Ventilation, and Air Conditioning (HVAC))
by JeffOYB
11/19/2018 11:08:06 AM(UTC)
Coleman Evcom furnace stops, need cool down
by newkid@north
12/14/2017 8:36:35 PM(UTC)
Furnace will not heat
by zomalaja
1/3/2017 7:51:36 PM(UTC)
power surge furnace dead now
by mutineer
9/15/2016 1:53:26 PM(UTC)
furnace won't shut off
by bowert
2/21/2016 11:19:04 PM(UTC)
furnace not working
by rebelbob
2/25/2015 3:04:54 AM(UTC)
Furnace blower turning on and off
by splumer
1/11/2015 8:07:00 AM(UTC)
Lennox G24M series Furnace Story and Questions
by drcarl
11/21/2014 7:59:29 AM(UTC)
Amana Furnace Condensate Leak
by LA_Homeowner
11/20/2014 10:02:33 AM(UTC)
Payne furnace blower on all the time
by vinhn
11/16/2014 12:36:57 PM(UTC)
Furnace blower turns off and on 3 times at the end of the heating cycle
by guy1
1/28/2014 11:35:22 AM(UTC)
furnace burn smell when heater on
by johnny wen
12/13/2013 11:43:21 AM(UTC)
Carrier Furnace Doesn't Work
by Dr_Zoidberg57
11/16/2013 5:26:15 PM(UTC)
Buzzing Sound From Transformer In Furnace
by lacoppari
10/4/2013 2:45:29 AM(UTC)
Blower problem on a Janitrol GMP 125-4 furnace
by needshelp2XYZ
7/7/2013 12:49:53 PM(UTC)
