The dryer won't start. I have checked the power supply, and I am getting power. I also cheked the start switch for continiuty and it is ok. Waht else should I checked?
If you have a meter and you checked the power and was getting 240 volts,i would then check the door switch for continuity.
Thanks but, I checked the door swicth and it has continuity. What else should I checked?
i have a whirlpool dryer with the same problem my dryer door switch has a brown and blue wire on the left side and a white on the right i checked the blue to white and get a connection but when i check brown to white nothing ? is switch bad?
if you make the switch you should have continiuty, if you do your switch is ok.
